Engine mount help needed please. >
Old 01-16-2023 | 10:32 PM
Originally Posted by xlint89
And to add some info.
If you look at the pic of my bilge on the inside of the bases you can see a piece of tape. That was used to hold the "plug" in place until the silicone set up.
If you only siliconed the cut out plug back in, I would definitely keep an eye on that area for stress cracks when you are back on the water.
Essentially you cut a hole in a stringer support and siliconing the plug back in will not have the same strength as it did when it was solid fiberglass.
Griff is offline
Old 01-18-2023 | 08:02 PM
Point taken. Thank you.
I did think about that before doing it. Not very thick (3/16" ) fiberglass in that location. Obviously a round hole and in the center, not near a corner. My thought was like an arched bridge for strength.
Will keep an eye on them though. Can always glass them back in if need be. Even when the engine is installed.
xlint89 is offline
Old 01-23-2023 | 03:49 PM
xlint, in the same position as you! would love to use an offshore style mount but unfortunately my stringers are inaccessible without major work to get other style of mounts to work. Are you going to use upgraded pedestal mounts or keep stock? Ill post a pic of my setup after i have 10 posts lol
CheckmateScarab is online now
Old 01-23-2023 | 04:15 PM
Checkmate,
Find a dead thread and just spam it to get your ten posts in.
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 01-23-2023 | 11:06 PM
Am waiting for a set of the solid mounts to show in the mail.
xlint89 is offline
Old 01-24-2023 | 11:32 AM
I will most likely order a set of the billet mounts at hardin or CPP as well then while the engine is out. Ill post a pic of my setup (old pics, ignore the mess, its all cleaned up). Refreshing the engine and replacing the entire transom assembly / bilge pumps / wiring etc and figured new mounts would be in order. I would absolutely love to have offshore style mounts but I dont see how anything other than pedestal mounts will work in my setup
Old 01-24-2023 | 07:58 PM
Yours, looks a lot like mine for sure.
There was a pic I was trying to find, but cannot now. In my search, I did see someone modified some angle aluminum to work on a similar set up as ours.
xlint89 is offline
Old 01-29-2023 | 06:51 AM
Originally Posted by compedgemarine
I have a set of the billet mounts for sale. they came with a bunch of stuff a friend wants to sell as he got rid of his boat. I dont know if they were even installed but do have a few nicks from bouncing around the shelves. $100 plus the shipping if your interested.
Showed up. Thank you.
How do I leave "feedback" for a smooth transaction? Thanks again
xlint89 is offline
Old 01-30-2023 | 07:48 AM
glad they made it. with todays shipping issues you never know. thanks
compedgemarine is offline
Old 01-30-2023 | 05:27 PM
To leave feedback, thought you click on his screenname, click on 'see i-trader score' and go from there, but now i get an error screen
outonsafari is offline
