E.O.I.C valve setings questtion >
Old 01-16-2023 | 01:05 PM
Witch valve are we talking about intake or exaust?
fbc25el is offline
Old 01-16-2023 | 01:12 PM
intake is 0.433 and exoust is 0.551..
Zole is offline
Old 01-16-2023 | 01:25 PM
Do you know where the intake is suppose to close abdc. Sounds like a lot of clearance.
fbc25el is offline
Old 01-16-2023 | 01:30 PM
Sorry i don't have a cam card.I think my crank is retarded a lot because i had truble with the faze of the engine(pistons hiting valves).
Zole is offline
Old 01-16-2023 | 04:34 PM
To check piston to valve clearance with a hydraulic cam you need a very light spring on the valves. If you just turned the motor over with regular valve springs you collapsed the lifter and your measurements are no where near correct.
Smitty275 is offline
Old 01-16-2023 | 10:48 PM
Thank you Smitty that is the solution to my problem...
Zole is offline
Old 01-19-2023 | 10:13 AM
Hey oso frends...found some light springs for my valves..Did the piston/valve messuring again and i got 0.236 inc gap.Since you told me it should be around 0.100 could it be that my crank is in retard...? Thank you
Zole is offline
Old 01-19-2023 | 10:46 AM
SB
I'm not sure where this thread took a turn, but before this valve clearance and light spring thing took place, we where talking about your cam probably installed wrong.
Or maybe I took a wrong turn. I can't remember. So many people with problems now a days. LOL.
Did or did you not have a multi keyway timing set ? Did or did you not check your cam timing with degree wheel set up.
Sorry if I'm behind.
SB is offline
Old 01-19-2023 | 11:00 AM
O my good SB..Yes i did have a 3-vay keyway and it was mounted wrong.When the dots where like this
the intake valve is hitting the piston.Then i found another 0 mark and i put it like this
then i have this 0.236 gap..Because i live in a vilige far far away i dont have a degree disk.So i took clay and soft springs and got this messurment
Zole is offline
Old 01-19-2023 | 11:38 AM
The timing set is installed correctly. The keyway on the crank is not supposed to line up with the dot on the cam gear. If you put the 0 on the keyway, then you use the 0 on the crank gear to line up with the dot on the cam gear.
snapmorgan is offline
