Testing the steering
Old 08-01-2023 | 07:38 AM
The u-bolt nut part number is 11-134371. Can I just buy this at the hardware store instead of a marina? Does it matter?
Prestigeworldwideee is offline
Old 08-01-2023 | 10:54 PM
Originally Posted by Prestigeworldwideee
If it is the gimbel ring which I assume it is… I got one quote so far:
Gimbal ring=$1547.00
swivel pin=$320.00
steering leaver=$300.00
plug kit=$30.00
Swivel pin seal=$28.00
Boots=$300.00
Trim sender (if needed)=$160.00
Labor=$1000.00-$ 1500.00
And they’re pulling the engine…
what else can i do to diagnose my problem?
Better off to just replace the entire transom assembly
Griff is offline
Old 08-12-2023 | 01:52 PM
Can anyone explain to me what exactly I’m looking for to figure out why I have this much play in the outdrive? I don’t have a clear understand of how it all works, so that’s an issue. I’ve just been wiggling the outdrive back and forth trying to see the parts affected.
It’s tight when outdrive is turned towards the passenger side
The space that’s created turning the outdrive towards drivers side
