Daytona CD1
Old 12-11-2023 | 04:50 PM
Default Daytona CD1
I’m getting ready to instal my box but have a few questions. Initially I am just going to use the box without controlling the timing, much like a msd box. I have a msd ready to run distributor with an aftermarket 14 degree bushing to keep the advance higher at idle. I plan on running the pre programmed #7 with idle stabilization. Is it necessary to hook the box up to a computer prior to using it both as just a “msd box” and or ignition controller. I bought a cheap windows laptop but I am pretty computer illiterate and don’t really get beyond my iPad 😂. Thanks in advance !
smokediver is offline
Old 12-11-2023 | 05:02 PM
just be careful or confirm polarity etc on your ready to run distributer. When I had mine on the dyno…. I had already purchased a couple pertronix distributors for previous project and it was a bit of a pain but was rushed also. The distributors were suppose to be able to be used both ways but needed to be wired differently than the non RTR. Had techs from each company on the ph that morning but I said screw it and just used the distributors as ready to run with a coil.
note: though I couldn’t use the cd1 coils either. We just put on a MSD blaster coil for dyno. Ran that way this summer for 30-40 hours but look forward to the cd1 distributors and getting dialed in. Docking was a bit of a beiotch. Sound killer but slightly embarrassing! 😂
getrdunn is offline
Old 12-11-2023 | 05:49 PM
Thanks ! Yeah I am not using the green / violet wires , I am running the orange wire off my distributor to the white wire on the box. Red wire off distributor to red on box and tie that into the ignition wire. I do have the coil as well but will hang on to the other just in case !
Old 12-12-2023 | 07:34 AM
resurrected's Avatar
You can just plug and play the box, that's how I initially got mine going. After running for a while I hooked my laptop up to it just to play with the idle stabilization a bit.
resurrected is offline
Old 12-12-2023 | 05:32 PM
seafordguy's Avatar
You don’t have to be a computer science major to use the computer software. If you follow the directions it’s REALLY simple and the idle stabilization, rev limiter and timing curve are what you’re paying for!!!
what you’re doing is the equivalent of buying a new Lamborghini and just sitting in the drivers seat and making vroom vroom noises……
seafordguy is offline
Old 12-12-2023 | 06:02 PM
I hear ya. I bought a cheap gateway laptop but there are some driver issues as the software from Daytona is pretty dated. The customer service has been really good and it will get worked out. My daughter is coming down for Xmas and I don’t want to get in too deep if there’s something wrong with the box or coil. So , I am hooking it up like an msd box initially and after the new year I am pulling and locking the timing and using the box for timing and Idle control.
Old 12-13-2023 | 01:36 PM
Glad I waited. May have to send the box back. Not for nothing , the software really needs updating.
