Cam and lifter choice 548ci >
Old 11-30-2024 | 10:22 AM
Default Cam and lifter choice 548ci
Hey guys.. this has probably been gone over a bunch but I need some advice on cam selection.. To give some info on what I am doing.. I have a Dart block, Eagle rotating assembly, je pistons.. using AFRs partial cnc 305cc heads, B&M 420 mega blower with superchiller and twin quick fuel 750 carbs.. I like the Crane 651 but I'd like it with a 4/7 swap.. I am running CMI headers and I'm trying to stay safe on 92* octane and no chances of reversion issues.. I would like to see 850-900 hp but obviously want it safe and reliable.. any help is appreciated..also, I am not opposed to buying a lightly used cam if anyone has a lead on.. thanks again
WR-1 is offline
Old 11-30-2024 | 06:58 PM
call bullet cams and tell them what you want.do it quick,,cores can be hard to come by.so be ready to buy
sutphen 30 is offline
Old 11-30-2024 | 08:10 PM
F-2 Speedy's Avatar
I dont see any way you will make that kind of power with those parts
F-2 Speedy is offline
Old 12-01-2024 | 02:53 AM
the 651 or an equil cam from another company would be a good choice.the heads would not be my choice and i think will hurt higher rpm power.what compression ratio are you at?
mike tkach is offline
Old 12-01-2024 | 06:39 AM
Does 750-800 sound reasonable with the correct cam selection?
SecondWind is offline
Old 12-01-2024 | 10:22 AM
thats more likely the power your gonna make,,torque will be pretty high too
Old 12-01-2024 | 10:49 AM
Thumbs up
Hey mike !! Good to see you post again.
Hope all is well.
ICDEDPPL is offline
Old 12-01-2024 | 12:27 PM
Probably 9:1.. I'd like to stay around 7-8 psi.. I already have the AFRs and I'm kinda committed at this point so if it can't make the power I'm going for, it'll just be what it is..lol.. I guess I was hopeful by what I've seen from others builds
WR-1 is offline
Old 12-01-2024 | 03:20 PM
F-2 Speedy's Avatar
I like the 651 cam, I built some 540's with those AFR 305 heads they made 630 hp through a 500 EFI intake, they had custom grind double swap billet core cams by Cam Motion dont know if they are still around or not.
Old 12-01-2024 | 06:22 PM
Those are good numbers.. How did your valve train hold up with this cam?
WR-1 is offline
