489 Stroker
I have a 489 BBC to replace my blown 516. I would like to reuse the cam from 516 if possible.
275/284 112lsa (Isky 39627584)
Holley 850
Dart Single plane intake
trying to decide what heads to get on a budget. Can get a good deal on a set of gm 088 heads locally but not sure if they’ll be sufficient enough.
any input would be great
Looking to get around 550+ hp
Holley 850
Holley 850
trying to decide what heads to get on a budget. Can get a good deal on a set of gm 088 heads. Looking to get around 550+ hp
Holley 850
What do yoy mean by budget? Getting a used set of heads cleanup up could be more than new afrermarket aluminum.
I can get a good deal on gm 088 heads locally but not sure if they’ll be sufficient enough to reach my hp goals. The heads I can get locally have new valves and valve job done by machine shop. Ready to go on engine
What WOT rpm are you lookong at for 600hp?
Not 100% on what the intakes were...probably iron. A good dual plane would help out there.
088 heads typically have factory cut valve seat throats that are just hogged out round and flat. Makes doing a quality valve job almost impossible. Increasing valve dia is an option...but 2.19" is very large already. The bottom of the Int ports is very low velocity.
Peanut Ports with a little bit of simple work would be better options...and can be had for $150/set used.
What compression ratio is it going to end up at ?
Personally I dont think that cam is going to be enough to reach your goal but I would call Isky and tell them exactly what you are trying to accomplish and see what they say.
