Bravo Upper Gears - Shimming? >
Old 04-10-2007 | 10:17 PM
Thanks for all your help D*ick!! I know I would have been searching for weeks to get a 1/10 of the information you gave. I am trying to get a lead and cost on the remaining parts I need to complete this job up in Canada. If I can't find anything I will give Sterndrivespec a call for the parts. 315-623-7642.
Again, I really appreciate you expertise and wiliness to help. I may give you a call once I get everything in hand
Thanks Again
Mike
pettem is offline
Old 04-11-2007 | 04:53 AM
Mr Gadgets's Avatar
Charter Member #601
You are welcome Mike! Feel free to give me a call.
D*ck
Mr Gadgets is offline
Old 10-13-2016 | 03:36 PM
The new bearing is. 125 thick. You need. 051,. 054 or. 057 shim. If you had. 091 you use. 051 ect
veloc410 is offline
Old 10-13-2016 | 03:55 PM
hopefully 9 years later he got it back together!
CDShack is offline
Old 10-13-2016 | 04:00 PM
Lol did see the date. Good one
veloc410 is offline
Old 05-21-2018 | 09:35 PM
Originally Posted by Mr Gadgets
The new procedure was in Supplement #28 ( I believe). It is the new procedure for the new style, new design upper case. And they look for .009-.015" @ .025 pinion depth, as AT said. Several tools are needed to measure it. The Supplement explains it well.
Hope this helps..
D*ck
Is it a supplement to manual 28 or is it manual 28?
Seahawk 2000 is offline
Old 05-22-2018 | 11:08 AM
Originally Posted by JaayTeee
I have a couple of different Bravo repair manuals
from over the years ( 2005 is the latest), and I've never seen anything about checking backlash in the uppers.
The only adjustments they list is the pinion bearing preload,
and the thrust bearing race/ case matching #'s.
It does have proceedures for checking backlash in the lowers
though.
Does Merc have a customer service manual, and a dealer
service manual, with the dealer service manual having
more info in it than the customer service manual does ?
The several that I've had apart are still going strong,
( knock on wood) but, the set up proceedures listed in my
manuals seem very basic, compared to set up proceedures
for a differential in a car, truck, or in our case, a forklift.
I like to check tooth contact, just to see where the
teeth are riding.
I have the upper gears out of my XR's getting cryo treated,
when I reassemble these I'll check backlash and see where they come in at.
How do you do you check the backlash? I can't find a manual that talks about checking backlash on the XR upper
Old 08-02-2022 | 10:11 AM
Bringing back and old post with good info.
Does anyone know where the "Supplement #28" that describes the procedure for pinion depth and backlash can be found? I cant seem to find it anywhere...
89Force235 is offline
Old 08-02-2022 | 01:46 PM
I believe that I have one in my toolbox at home. I will check this evening
snapmorgan is offline
Hot Boat
Drives and Lower Units
12
12-22-2007 12:27 AM
Illusive
10
07-10-2007 07:51 AM
johnnyboatman
05-02-2006 07:15 AM
otis311
6
06-26-2005 09:55 PM
2Slow
17
08-23-2004 12:13 PM
