Drive Shift hesitation >
Old 05-01-2007, 10:26 AM
Originally Posted by 25 hors la loi
Yes he engage normal ...but with a 2 to 3 seconde delay ..in foward and reverse ..... i have found a manuel on how to adjuste the linkage ...but it`s not the same than mine ....have you some info on how to adjust mine ???
Thank`s to take time to respond me
The cable you have circled is the shift cable from the
helm.
The drive cable is below that.
Here's a picture of the bracket.
http://www.mercruiserparts.com/Show_...2D+Design+I%29
Using D*cks proceedure for adjustment.
The barrell he mentions is mounted in item # 10,
it's held in by a cotter pin.
To increase the lenght of the throw, adjust the stud
( item # 15) upward.
hope this helps.
JaayTeee is offline
Old 05-01-2007, 10:58 AM
25 hors la loi's Avatar
Thanks JaayTeee ....my concern is in the manual i attached ....the shift cable from the helm
is not the same than the one mentioned ....i have no control cable barrel ...how can i found my backlash for control cable ???
And a big thanks you .....for your patience
25 hors la loi is offline
Old 05-01-2007, 11:50 AM
The barrell is on the drive shift cable, not
the cable from the helm.
The adjustments you want to check for are
with the drive shift cable ( underneath the helm cable)
JaayTeee is offline
Old 05-01-2007, 02:30 PM
[B]In the manuel ....it`s not the same than me ...but he speak about adjusting the backlash of the control cable .... i have to check for that ???
again sorry for my poor english ...and thanks to take time [B]
Attached Thumbnails Drive Shift hesitation-backlash-1.jpg   Drive Shift hesitation-backlash-2.jpg
Old 05-02-2007, 09:46 PM
Charter Member #601
Mr Gadgets's Avatar
25, I sent you a pm.. more later when I am not so tired..
D*ck
Mr Gadgets is offline
Old 05-03-2007, 06:41 AM
D*ck
Thank`s a lot ....it`s realy appreciated ....
speedreeder
Drives and Lower Units
4
02-12-2009 09:08 AM
bimini run
5
10-14-2005 03:56 PM
Sonic30ss
2
09-04-2003 01:54 PM
Interceptor
8
05-24-2002 01:22 PM
Audiofn
3
04-10-2002 10:19 PM
Quick Reply: Drive Shift hesitation
