Replacing Lower Shift Cable >
Old 04-19-2007 | 07:44 AM
Default Replacing Lower Shift Cable
how hard is it to replace lower shift cable on bravo drive?any special tools required?can anyone outline the steps after taking the drive off?
awsomethunder is offline
Old 04-19-2007 | 01:13 PM
Mindi
To install shift cable properly, you can follow the instructions in the service manual, if you have one. Note that you must have the shift cable adjusting tools or you won't be able to adjust it properly.
Doller Offshore is offline
Old 04-19-2007 | 02:02 PM
25 hors la loi's Avatar
I have found this website .... http://www.perfprotech.com ...alot of good info ....and maybe in Drives and Lower Units section .....we can add a Sticky Thread in top of this section with all technical reference ???...i joint two PDF ..hope that Help
File Type: pdf
File Type: pdf
25 hors la loi is offline
Old 04-20-2007 | 12:37 AM
articfriends's Avatar
I changed mine in a parking lot at a resort in NH,its not very hard,just make sure you get it adjusted right and that its not going to leak,Smitty
articfriends is offline
Old 04-20-2007 | 10:17 AM
I replaced mine thinking that it would be cake. Removing the portion that went through the bellhousing was a nightmare. Sometimes they seize in there and have to be drilled. I don't know what they make the brass looking part out of, but it was incredibly difficult to drill. I was using a brand new cobalt bit and had a very difficult time. They aren't always like that, or so I hear. Upon re-installation, make sure that you route the cable in a way that it won't touch the coupler. That's what wasted mine in the first place. I didn't have the adjustment tool but didn't have any problem getting it adjusted. In the end, could be easy or not.
Rene
oldandtired is offline
Old 04-20-2007 | 11:21 AM
NoQuarter
When I did mine, I had the adjustment of the cable totally screwed up. So I bought the Mercrusier shift adjustment tool and that really helped.
Old 04-26-2007 | 10:26 PM
Gizmo's Avatar
Are we having fun, yet?
Where can I get the bravo cable adjustment tool #91-12427 and the Alpha drive shift shaft stabilizer tool #91-809815A1?
What are the prices? Also, thanks for the info about the on-line manual. It gives a better step by step on the adjustments.
Jay
Gizmo is offline
Old 04-27-2007 | 05:50 AM
hp500efi's Avatar
Member #9
I did mine last year and it was not so easy. My old cable was a bummer to remove as it was tangled up down near the bell housing. Once old one was out, new one installed pretty easy. Merc tool makes it easy.
Member of the Liquid Jungle
hp500efi is offline
Old 04-30-2007 | 08:16 AM
Have you be able to adjust your`s ?? ....cause me i have another model ..... and i have to figure how it work ...and i don`t want to make mistake ...and cost me a lot of $$$
Attached Thumbnails Replacing Lower Shift Cable-linkage-engage-1-.jpg   Replacing Lower Shift Cable-linkage-engage-2-1-.jpg
File Type: pdf
Old 04-30-2007 | 08:52 AM
my cable looks like it makes a 90 degree bend into the bell housing.is this normal?
Bryan Rose
3
07-24-2008 08:53 AM
bsirk
Fountain
0
07-18-2007 02:34 PM
Sydwayz
17
08-14-2006 10:08 PM
bikinilover
2
03-25-2005 05:47 PM
Interceptor
2
07-19-2004 03:40 PM
