What is this part called???? >
Old 05-05-2007 | 01:17 AM
CAPTAIN CHUCK's Avatar
Default What is this part called????
My buddies kid knocked my old drive over and the 2 "teeth" I have outlined in yellow broke off. Is this part replaceable and if so what is it called? I looked on Bam's site but couldn't locate it....
CAPTAIN CHUCK is offline
Old 05-05-2007 | 05:18 AM
Vinny P's Avatar
I hate the winter!!
Take a look at part 26..
http://www.mercruiserparts.com/Show_...%28STANDARD%29
Vinny P is offline
Old 05-05-2007 | 11:34 AM
That's the one....Thanks bro. I owe you one.
Chuck
Old 05-05-2007 | 12:04 PM
There's no need to replace it. Those teeth are only there so that you can put the wrench on it. Replace it next time it has to come apart.
Rene
oldandtired is offline
Old 05-05-2007 | 05:25 PM
Cool....Thanks O&T that sounds good to me.....
Old 05-05-2007 | 05:48 PM
Mbam's Avatar
Offshoreonly Advertiser
uh - I don't mean to be ...... but that corrosion on the u joint says to me you have bigger problems. Don't even think about installing that drive without checking the gimbal bearing & u joints.
Mbam is offline
Old 05-05-2007 | 05:53 PM
I have already cleaned all the outside parts and I am going to open the drive and check it out this week. The gimbal bearings were only 2 months old when Katrina hit and they only had about 6 hours on them. They should be good. Thanks Mbam.....
Chuck
Old 05-05-2007 | 06:11 PM
J-Bonz's Avatar
Chuck
You have the drive of now, Your there, Just replace it.
You'll be happy you did
J-Bonz is offline
Old 05-06-2007 | 11:22 AM
Mr Gadgets's Avatar
Charter Member #601
That is called a pinion bearing retainer nut.. Merc calls it a Ring Nut.. Here is what you should replace it with.. I sent you a pm on it.. Chuck.
Attached Thumbnails What is this part called????-100_4681a.jpg   What is this part called????-100_4682a.jpg
Mr Gadgets is offline
Old 05-06-2007 | 05:44 PM
Big Block Billy's Avatar
Post
That looks like the original style that was used on late 60's Merc. drives to about 1971 or so. I guess the bean counters wanted to save money and discontinued making them out of brass.
Big Block Billy is offline
