trim problem pls help >
Old 05-30-2007 | 02:45 PM
The sender could be bad or stuck inside. It could also have a short or bad wire. They are a pain to replace as the wires go through the transom assembly and plug in inside the bilge.
The sender just works on a pendulum type balancer inside that sends a signal to the guage.
Its basically already bypassed with the trailer/trim switch.
Griff is offline
Old 05-31-2007 | 07:34 AM
97BossHammer's Avatar
But is there a way to bypass it with the throttle switch, that'd make things a whole lot easier.
I've seen some posts about wiring it by the trim pump using a jumper , but I'm not exactly sure what to wire up???
97BossHammer is offline
Old 05-31-2007 | 08:22 AM
ziemer's Avatar
I'm pretty sure it's a black 2 conductor wire that looks similar to a lamp cord. You can use a piggy back connector and jumper them together. (I've done this before, but it's been awhile. )
ziemer is offline
Old 05-31-2007 | 08:34 AM
hoozeyurdaddy's Avatar
behind the motor there is 2 black zip wires comming through the transom for a total of 4 wires, 2 wires are for the trim sender and 2 are for the trim limit, the trim limit is the ones that let you operate from the throttle or from the trailer, the limit switches have 2 male bullet connectors on one side and 2 female on the other side, find those wires and jump them together and your trim switch should work if the sender is the problem. but at that point the system will nolonger know what positon the drive is in, so you will have to trim by feel.
hoozeyurdaddy is offline
Old 05-31-2007 | 08:40 AM
is this what I should do?
http://www.offshoreonly.com/forums/a...1&d=1154390311
also here is pump......confused as to which wires to connect together.
http://www.offshoreonly.com/forums/a...1&d=1145981538
Old 05-31-2007 | 08:52 AM
no to the first one, that is just a test to check the pump.
on the second one, the wires are there, but you can't see them, look behind the motor at the transom plate above the coupler, you will see 2 black exstension cord looking wires, they should be zip tied up so there out of way, find those wires and you will see the bullet connectors that i'm talking about.
Old 05-31-2007 | 08:54 AM
ziemer's Avatar
Originally Posted by 97BossHammer
No. This first one is showing how to test your solenoid. It's bypassing the solenoid and putting power directly to the trim motor.
ziemer is offline
Old 05-31-2007 | 09:57 AM
OK so once I find the 2 black extension cord looking wires at the transom plate and the bullet connectors........then what do I do?
Sorry for the dumb questions....just want to make sure I get this right.
Old 06-01-2007 | 08:10 AM
on one set of cords, there are a male and female bullet connector, those are for the trim sending unit gauge, on the other set of wires, there are 2 male connectors, those are for the trim limit, these are the 2 wires that you want to connect together, unplug them and the wires on the engine side need to be hooked together, that should make your trim switch on your controls work, it will bypass the trailer button and you will have full control of your trim and tilt from the shifter.
Old 06-04-2007 | 08:51 AM
OK got it done, excellent directions.
Thanks very much for the help guys.
tkrivitz
10
07-14-2008 04:30 PM
boatnt
5
04-21-2007 04:28 PM
never enuff
Baja
24
10-24-2006 03:54 PM
u150
6
06-16-2004 01:42 PM
