trim problem pls help
I can trim the drive down......but using the throttle switch to trim it up does nothing, I can use the "trailer trim switch" and it trims very slowly to a certain point. I've adjusted the trim indicaters on the drive but this made no difference.
Also when running in the water it trims down fine, but when trying to come up the trim pump sounds like its all over the place, it whirls up and starts spinning all over the place........any suggestions???
Had this happen to me not too long ago.
If the motor continues to run but it looses it's lifting ability the pickups are probably clogged. The resevoir will build up sludge at the bottom and clog the mesh socks on the ends of the pickups. Disconnect the lines and pull the pump out of the boat. Remove the resevoir and dispose of the oil. Clean the resevoir out and also clean the mesh socks.
OK I think I have the trim indicators screwed up also, gauge reads that the trim is up even though it's not.
Is taking the pump out a fairly easy job.......trying to figure out if this is something I can do.
Are there any special tools that are needed to get the pump out? I also noticed on the starboard trim adjustment that one of the wires is cut just a little, wonder if this has anything to do with it.
I'd like to tackle this job myself, can anyone tell me if it's fairly easy or ????
Nordic95
You hit the nail on the head......boy was it nasty.......gunk was all in it. I cleaned out the reservoir and got it all working, comes all the way up now. The throttle switch only works going down and I have to use the trailer switch to bring the drive up.....I think this is just a faulty switch though.
This is due to your trim sender setting on the drive. You said it shows up even when the drive is down. Adjust it so it shows down when the drive is down and it will work fine. Its a protection to keep form trimming too high and damaging the U Joints.
Ok, have been trying that but I can't get it set right for some reason. I've turned it all the way in both directions but still same thing. trying just moving it slightly now till I find the right setting.....
