TRS LH or RH
Old 05-22-2007 | 06:25 PM
Pantera24's Avatar
Default TRS LH or RH
Ok single 454/420 with BW tranny, which drive to use RH or LH ??
Please explain why, because I cannot understand this for the LIFE of me!
Pantera24 is offline
Old 05-23-2007 | 09:35 AM
Pantera24's Avatar
TTT
Anyone?
Old 05-23-2007 | 09:43 AM
i believe that the left ones were not as strong as the right's. Search on oso i think you will find some info
djtalon is offline
Old 05-23-2007 | 09:50 AM
Pantera24's Avatar
Ok I guess i didn't ask my question correctly.
If you got a boat that had no outdrive on it just the engine, b/w tranny and TRS gimble. Which outdrive do you go with LH or RH or does it even matter.?
Old 05-23-2007 | 10:03 AM
If you have to buy the drive i would consider a KONRAD, otherwise a right handed drive
djtalon is offline
Old 05-23-2007 | 11:38 AM
Audiofn's Avatar
Charter Member #232
Right hand
Put your best foot forward!
Audiofn is offline
Old 05-23-2007 | 11:51 AM
CIG3's Avatar
Right hand.....
CIG3 is online now
Old 05-23-2007 | 11:52 AM
Right hand, due to prop availability if nothing else.
rdoactive is offline
Old 05-23-2007 | 01:10 PM
Biggus's Avatar
Actually the left hand unit is stronger than the right hand drive due to placement of the lower drive gear. It is located in the bullet, in front of the pinion gear and is supported much better than the right, which is located up against the bearing carrier and can move around some.
Konrad sets up most single engine boats with a left hand unit whenever possible.
Biggus is offline
Old 05-24-2007 | 02:57 PM
rws's Avatar
rws
My 20' cigarette has a lefty,but the steering is also on the left.The left hand propellor rotation is supposed to counteract the the engine torque. Also what Kurt said has been proven to be true on many high horsepower twin engine boats because the RH drive almost always fails long before the LH.
rws is offline
redcorvetteman3
Drives and Lower Units
14
10-07-2008 06:58 PM
GoFastSonic
Classic Offshore
8
05-12-2008 09:48 AM
42johnny
14
04-18-2008 09:49 AM
jeff1000man
02-27-2007 09:45 AM
