Staggered motors and drivelines >
Old 06-06-2007 | 05:52 AM
MarkDonzi's Avatar
Default Staggered motors and drivelines
Hi Guys, I own a 2005 Donzi 38ZR with staggered 525's. I just completed a complete rebuild of my Bravo XR drives at 225 hours. Complete bearings, seals and upper gearsets.
In my setup, the staggered or forward engine has a driveshaft between the engine and the drive that is about 2-1/2 feet long. This driveshaft has U joints and bearings, etc. at each end.
Since the drives were ready for rebuilding at this time, I'm wondering what if anything I should be doing to this driveshaft area.
Thanks,
Mark
MarkDonzi is offline
Old 06-06-2007 | 01:43 PM
monstaaa's Avatar
i would change the u-joints and have the shaft rebalanced. also consider the pilot bearing( thats the bearing support bolted to staggered engines inner transom plate).
monstaaa is offline
Old 06-06-2007 | 01:55 PM
It's been my experience that these parts, on TRS and Speedmasters anyway, are really well built.
If you grease the u joints and carrier bearings regularly, they will last a long time.
My $0.02
rdoactive is offline
Old 06-06-2007 | 02:18 PM
monstaaa's Avatar
but these are bravos.
monstaaa is offline
Old 06-06-2007 | 03:03 PM
Geeez, did they build anything to last on a bravo?
Old 06-10-2007 | 01:17 PM
monstaaa's Avatar
small sacrifices yield large and significant savings.
monstaaa is offline
302Sport
09-19-2008 01:19 PM
robhtg1
Fountain
8
09-03-2008 11:21 AM
pkspx
Active Thunder
141
10-18-2007 02:20 PM
32 thunder
07-09-2005 10:09 AM
rfoxx987
Fountain
34
05-16-2005 10:43 PM
