Help with Drive
Old 07-12-2007 | 11:56 AM
Default Help with Drive
Guys i just broke my lower unit for my alpha last weekend. I would like to upgrade but I can not afford a Bravo right now. Is there any upgrade from the Alpha 1?
Skeed UP is offline
Old 07-13-2007 | 07:43 PM
Sorry to hear about the Alpha. What in the drive failed? What were you doing when it broke?
The Alpha due to it's design cannot really be made much stronger. It's case is small and you cannot utilize larger gears or shafts. The only upgrade is to use HD gears in the upper case. Merc and GLM make these. I went with a set in both my primary and spare Alpha's just in case as I am putting
400hp thru it and drive it pretty hard at times.
Ryan00TJ is offline
Old 07-17-2007 | 10:13 AM
Call me, we might be able to help. Have some rebuilt Alpha's in stock. 954 237 0332
John the Drive Man is offline
Old 07-17-2007 | 11:16 AM
I was basically riding along. I guess i was pushing kinda hard. Damn man i would love to upgrade to a Bravo, but they are not cheap. How much would a new bravo 1 cost me?
Skeed UP is offline
Old 07-17-2007 | 05:31 PM
A Bravo 1 does not just bolt up. Its a big project in the 10k range to have done.
Griff is offline
Old 07-18-2007 | 06:16 PM
tonypo8's Avatar
I have a low hour, fresh water, low water pick up bravo off of my Gun. I upgraded to xr's and have this as an extra, and I am looking to make a deal. I will take $2250 for the drive. I also have gimbals. Let me know if I can help.
Tony
tonypo8 is offline
Old 08-07-2007 | 08:30 AM
I'm also running 400hp through my 1984 Alpha. No problems. Only upgrade is re-sealed and re-shimmed drive, added drive shower, and check drive oil before every outing (soon adding remote tank for this, like newer style). If you don't use full throttle on take off, it should be OK. Bravo is heavier and larger, so it will go slower. I would say it depends upon your boat weight. I have a 17' Formula that weighs almost nothing. I even use auto rear axle gear lube, 85W-140, not even stern drive lube ($$$).
Bravo upgrade is about $1500 for a used drive, and another $1000 or so for the used gimbal ring. Then, you'll also have to add a belt driven water pump mounted on the engine to suck lake water. This is seperate from the circulation pump you already have on there.
You can buy a brand new Alpha drive from aftermarket for about $1200, with warranty. I have heard nothing but good stories about them. You can also buy just lower or upper from them for about $600 each.
SmallPP is offline
Full Force
Drives and Lower Units
3
10-15-2007 07:29 AM
Canada Jeff
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
