Stalling Alpha
You could also have a bad shift interupt switch, but check the cable adjustment first...
Jamie / Lakeside
Jamie / Lakeside.
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
When you replaced the shift cable did you replace the bushings and seals in the shift shaft that's located in the bell housing on the transom assembly?
These bushings and seals tend to wear out and leak, which is what makes your shift cable go bad to begin with. Over time the shift shaft in the bell housing gets tight which puts excess pressure on your shift interrupt assembly which causes it to stall when going into gear and coming out of gear.
formula31
04-16-2002 09:50 PM
