Alpha oil change ??? >
Old 07-18-2007 | 01:32 PM
Default Alpha oil change ???
My 223LS formula has the 454 mag with an alpha outdrive, yes I know that drive unit really doesnt get along with big blocks but heres my question-I changed the oil about 20 hrs ago and I'm changing it again, what oil would you use in an alpha to extend its life??? I'm thinking Royal Purple Max-Gear?
75-90? I baby this boat on take off and am very careful when it comes out of the water so I dont blow this thing up but I want to give it the most protection I can. Presently I switched to RP 20-50 Synthetic for the motor with no problems. Thanks for all the help I've recieved on this site its a great place for info and making friends.
prosno is offline
Old 07-18-2007 | 02:35 PM
Knot 4 Me's Avatar
The RP would be a fine choice.
Knot 4 Me is offline
Old 07-18-2007 | 03:10 PM
I've used the Merc Hi Perf Syn from 92-2002. Since then i've been using Mobil 1 Syn 75W-90. All are 25-30hr change intervals. I also run a drive shower and gear lube resevior to keep things cool and lubricated. No blown Alpha's over 4 350-400hp SBC's.
Ryan00TJ is offline
Old 07-19-2007 | 06:10 AM
Well old oil had about 20 hrs on it and was pretty darn clean when it came out, had to look real close to see a few small micro hairs of metal on plug magnet. Filled with royal purple 75-90 Maxi-Gear so lets see how it does. Thanks for the info guys.
prosno is offline
Old 07-19-2007 | 07:51 AM
put a Simrek drive shower on it for sure.......
pullmytrigger is offline
Flamingo 42
Drives and Lower Units
9
05-10-2008 08:37 AM
duunoit
11
05-18-2005 05:52 AM
SkiDoc
23
12-22-2004 09:43 AM
mleslie951
27
11-08-2004 08:03 PM
jeffg
2
08-24-2003 09:01 AM
