Need Prestolite pump help >
Old 09-16-2007 | 10:35 AM
Default Need Prestolite pump help
I am restoring a 76 cig 28ss and am having a problem with the trim sytstem. the drives will trim up/out normally, together and sound fine. the problem is trimming in / down. the pumps sound like they are under heavy load and the drives are moving very slowly. I never ran the system before the restoration so I dont know if this is what they were like before. I feel like it is a valving / pump issue. I checked the pressure on the up and down side and they are to specs at I believe 2200psi up and 600 psi down.
the only other thing I think could be a problem is that I have 2 cylinders with solid pistons and 2 with valving. I installed them 1 and 1 on pt and stbd.
any insight into this would be greatly appreciated.
thanks guys
Chris
Attached Thumbnails Need Prestolite pump help-imgp1570sm.jpg   Need Prestolite pump help-imgp1571sm.jpg   Need Prestolite pump help-imgp1573sm.jpg
chrissbb is offline
Old 09-17-2007 | 08:33 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Are you running the same size diameter lines on the down side? If not you could be restricting the volume...
There are also newer pumps & rams that will move up & down faster.. However yours should be about the same speed both ways amd if anything many times the drives go down a little faster as gravity or load usually is an assist..
J
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 09-17-2007 | 10:01 AM
Mbam's Avatar
Offshoreonly Advertiser
Very common for the shock valves to come apart inside the cylinders.
Mbam is offline
Old 09-17-2007 | 03:41 PM
I had everything apart - cleaned and reassembled - so there is no "mechanical" issue with what I have. both sides have the same size lines.
I think there may be a mismatch problem?
doe anyone know the reason for having solid and valves pistons? and do they serv any function other than overpressure relief?
I have also seen other prestolite pumps with different pump/ valve housings is there a difference?
Thanks for your help
Chris
chrissbb is offline
BillR
11
07-29-2022 06:31 AM
HP500Hammer
15
01-30-2008 06:03 PM
ratman
17
04-19-2006 09:35 PM
excaleagle42
4
09-04-2002 07:52 PM
