Slow shifting
Old 09-21-2007 | 05:11 PM
Question Slow shifting
I have a 91 Baja with twin big blocks and Bravo 1 drives. One of the drives is slow to go into gear when shifted. Does this in forward or reverse. Takes 3-4 seconds to go into gear while the other side goes in as soon as its shifted. Engines are idled at 750 rpm. Anyone have any ideas??? Thanks in advance.
team Tickfaw is offline
Old 09-21-2007 | 06:26 PM
My bravo was doing the same thing, did it for two days then the upper let loose. Brought it to the shop this week to find out the damage. Don't know exactly what it is, but mine was hesitating the same way. Not much help(I know). Just though I'd let ya know.
Scott
fast22 is offline
Old 09-21-2007 | 07:40 PM
I had a similar delay on Stbd side... slow to go into gear. The shifter cable was out of adjustment... that fixed it. Carder
Carder is offline
Old 09-21-2007 | 08:36 PM
teamTickfaw, if its doing it to both fwd and rev I would first check for loose linkage on shift plate at motor and check lower cable where it enters bellhousing at drive. If you trim out and turn wheel to port inspect cable at bellhousing. If the cable is coming apart at the brass swedged end you loose travel. It could be something else but check these easy things first.
Jim
MOBILEMERCMAN is offline
Old 09-22-2007 | 06:44 AM
Thanks, I will look for the easy things first. Just did'nt know where to start.
Old 09-22-2007 | 06:47 AM
Fast 22 let me know what you find. Thanks.
Old 09-22-2007 | 02:15 PM
Also how do I adjust the shifter cable and at what end, shifter or at outdrive ?
Old 09-22-2007 | 02:35 PM
Carders shift was adjusted after his engines were out. During the exchange something must have moved. Generally no adjustment is needed, if the shifting has changed something is going away. Adjusting the cable is treating the symptom not the problem. Drives are expensive as you know. Good luck.
Jim
Old 09-22-2007 | 03:27 PM
Jim's correct.. the symptom didn't appear until the engine was re-installed again. At that point when both shifters were put into neutral the stbd. was well ahead of the port on the shift pad. We unhooked that cable at the engine, then put the both shifters where we new neutral was on the port, and adjusted the cable to length at the engine end. Carder
Carder is offline
Old 09-23-2007 | 07:12 PM
Scarab28's Avatar
Just went through the same thing, replaced the shifter cable and drive shifts like new again. This was on a 1989 Bravo, guess they are only good for about 15 years, not bad. Couldn't really see the damage until you compare the old one next to a new one.
Scarab28 is offline
