merctrans ll  problems >
Old 10-29-2007 | 09:09 PM
Default merctrans ll problems
i recently had my bellows replaced on a 1974 255 mercruiser and on the first trip out the spring on the front of my tr outdrive yoke cut thru the output shaft seal of my merctrans ll ... i think the people who replaced my bellows must have done something wrong ... what should i be looking for ? is there a washer in between there or could they have put in the wrong spring ? bent the spring any help appreciated , thanks in advance
dlarson is offline
Old 10-29-2007 | 09:52 PM
Mbam's Avatar
Offshoreonly Advertiser
Yep, there is a washer, it is held in place by a small o ring, probably tore.
Mbam is offline
Old 10-30-2007 | 07:08 PM
Default thanks for the help
does anybody know where i can find this output thrust washer part #12-62684 ? i have checked all the places i know of to order parts for this merctrans ll
dlarson is offline
Old 10-30-2007 | 08:19 PM
Default Merc Trans
Check KC marine in Bellingham Washington. That guy has every thing for the Merc Trans
GoFastSonic is offline
Old 11-02-2007 | 08:13 PM
rws's Avatar
rws
If kirk (KC Marine) does not have one I could make you one for a reasonable price.
P.S. Kirk Cody is a real good guy
Rob
rws is offline
Old 11-02-2007 | 10:45 PM
Mbam's Avatar
Now that I think about it most likely your washer is lying in the bottom of the housing at the back of the trans, just in front of the aft bearing. See if you can look in there with a mirror. I can't remember for sure but you might be able to poke a finger in there. That's where it would land if the o ring broke. If you are stuck let me know, I'm sure we have one someplace around the shop.
Mbam is offline
GoFastSonic
Drives and Lower Units
8
10-26-2007 07:07 PM
GoFastSonic
OPA/The Jersey Boyz
5
10-24-2007 07:04 PM
scottie150
10
08-28-2006 07:49 PM
WHITE-DIAMONDS
05-16-2003 11:59 AM
Firewalker
3
05-31-2002 03:16 PM
