What's the scoop on this Bravo? >
Old 11-09-2007 | 10:53 PM
mikeb4's Avatar
Back out of the Game!
Default What's the scoop on this Bravo?
I picked up a Bravo One X Diesel 1.5:1 with serial number OL750***. What year is the drive and what is it's capability?
Thanks, Mike
mikeb4 is offline
Old 11-09-2007 | 11:03 PM
Veteran: Army
Not sure about anything else, but my Bravo 1 from 1998 is serial number OL151***, so that might give you some idea of sequence.
-Andrew
DrFeelgood is offline
Old 11-10-2007 | 07:14 AM
mikeb4's Avatar
It does have the low water pickup which is a nice feature.
mikeb4 is offline
Old 11-10-2007 | 11:37 AM
Mr Gadgets's Avatar
Charter Member #601
Without looking inside, I am guessing. Seeing that it is OL serial number, it indicates the old style thin floored gears. The thick ones started with the OM drives.
I read an article once that mentioned the Diesel gears. They were nothing more than shot peened. But they were the B1 gears.
Not sure if they used a heavier vertical shaft in them or not.
I found the article and I can email it to you if you like. Big files so it would have to wait till I get to work on Tuesday??
Or pm me with your address I can send you a copy of article.. I found it in Family & Perfromance Magizine. Sept 2001.
Hope this will help.
D*ck
Mr Gadgets is offline
Old 11-10-2007 | 02:23 PM
mikeb4's Avatar
D*ck
Thanks, I was hoping for a heavy duty version of the B1 with it being an X Drive and low water pickup, I am running 500 HP in a single 28.
Mike
mikeb4 is offline
Old 11-10-2007 | 10:17 PM
mikeb4's Avatar
Default Pics
I thought I would post some pics to help clarify what's on my Drive. It clearly says "X" and Diesel on the decal but it is a OL750 number with low water pickups on both undersides of the torpedo. Any info regarding the gearset capability would be great .... I guess I want to confirm this drive would have the "X" gears and not the standard style thin floored.
Thanks!
Attached Thumbnails What's the scoop on this Bravo?-cimg1686.jpg   What's the scoop on this Bravo?-cimg1689.jpg
mikeb4 is offline
Old 11-11-2007 | 11:44 AM
Mr Gadgets's Avatar
Charter Member #601
Mike,
The easy way to verify it is has X gears in it is to pull the top cap and measure the length of the tower race. That would be the bearing race that is pressed on the alumminum tower on the cap. If that race is 1" long, then you have the thin floored gears. If it is closer to 7/8" then it will be the thick floored gears.. That is the easy way to tell. Although I have seen a mix and match, that is very uncommon..
Hope this helps..
D*ck
Old 11-16-2007 | 07:04 PM
tripps's Avatar
can anyone tell me what drive this is? i know its a 1.5 gear but the sieral# is oc810389??? it has a xr cover on it,but who knows tripps
tripps is offline
Old 11-18-2007 | 08:52 AM
The only difference is, it has spiral gears instead of straight gears.
JohnTheDriveMan is offline
Old 11-20-2007 | 08:25 PM
Mbam's Avatar
Offshoreonly Advertiser
I hate to say this but it looks like a new decal on an older drive. X drive did not start until 0M serial number. See if this helps:
http://go-fast.com/mercruiser_bravo_sterndrives.htm
The 0C drive is a 1991 or so. Way before the XR was released.
Mbam is offline
