Removal of Gimbal Transom Assembly >
Old 11-30-2007 | 04:41 PM
Default Removal of Gimbal Transom Assembly
I am trying to remove the transom assembly from my boat. I have a Bravo 1 drive, the motor is out, and lower unit is off, and I want to rebuild the transom assembly. It needs to have the steering tightened up and the bellows replaced. I can't seem to figure out why it won't come off the back of the boat. I have the 6 nuts and 2 bolts off, the shift cable and steering is disconnected. But it will only come apart about 1/2 inch, and then something is holding it on. I got to be missing something, all help and suggestions are appreciated.
cliff3466 is offline
Old 11-30-2007 | 05:43 PM
You have the inner plate off too? Depending on how straight the holes were drilled its possible the studs are jamming. You may just need to work it off with a block of wood and/or a no bounce hammer.
Jim
MOBILEMERCMAN is offline
Old 11-30-2007 | 08:39 PM
Vinny P's Avatar
I hate the winter!!
If that doesnt work, try dynamite!! Those damn things stick bad some times. Be careful that the water neck isnt hitting the transom hole when pulling it back.
Vinny P is offline
Old 12-02-2007 | 08:38 PM
ROB FREEMAN's Avatar
Som People Add A Nice Bead Of Sillicone To The Mating Surfacs , Thus Making Them A Sum ***** To Get Off . I Know When I Changed Mine , Somone Had Put A Heck Of A Bead And It Stuck Like Hell, Ended Up Using A Pry Bar To Get It Started .
ROB FREEMAN is offline
Old 12-03-2007 | 08:57 AM
jryan26's Avatar
If its coming off a 1/2 inch, mercman is probably right about the bolts getting hung on the holes.
jryan26 is offline
CN24
Drives and Lower Units
3
05-31-2008 08:34 AM
offshoredrillin
Wanted
12
01-04-2008 02:02 PM
klaw
6
03-06-2006 06:23 PM
jdub
02-20-2006 05:41 AM
Ran-Dom 32
22
03-24-2005 09:28 PM
