Blackhawk drives. Rooster Tail? >
Old 01-21-2008 | 12:55 AM
Default A P-29 throws a nice roost
Nova26,
My P-29 at the Oshkosh Thunder Poker Run
Attached Thumbnails Blackhawk drives. Rooster Tail?-p1010005.jpg   Blackhawk drives. Rooster Tail?-p1010005-1.jpg   Blackhawk drives. Rooster Tail?-p29_1.jpg
OshkoshThunder is offline
Old 07-02-2008 | 08:38 PM
Mark is that exaggerate trim running down the lake to make the big roster tail? Or is that just trimmed properly to run hard? Just curious.
Dan
nova26 is offline
Old 07-03-2008 | 10:09 AM
JasonSmith's Avatar
I always thought the P29's were cool looking boats.
That is all, just thought I'd throw that out there.
JasonSmith is offline
Old 07-03-2008 | 11:49 PM
Default Black Hawks are Surface Drives
Dan,
The Black Hawks you see in the pictures I posted are at about a half a click above straight trim on your Livorsi guage. Since they are surface drives, they send a rooster similar to a number six, but not the same volume. Put it this way, I did not loose any speed because the drives were out too far....
Old 07-03-2008 | 11:52 PM
Dan,
In the middle of setting up a 28 Talon with 600 HP and a BlackHawk. Will send some pics of that when done and running. Should be in the next week or so...
Old 07-03-2008 | 11:54 PM
Jason,
There are a few 29 Scarabs out there you can set up with Black Hawks on them. Come on - trade that Baja in for a Scarab. :-)
Old 07-04-2008 | 08:04 AM
JasonSmith's Avatar
Originally Posted by OshkoshThunder
Jason,
Ummmmmm, no!
Old 07-04-2008 | 01:59 PM
Dan,
Be watch n! Thanks Mark
Dan
nova26 is offline
Old 07-14-2008 | 04:40 AM
Originally Posted by Airpacker
When I first rigged it, I never gave much thought to the fact that factory, they had the exhaust routed thru the drive to airate the props. I blew a vertical shaft in two trying to get on plane. Repaired the drive, designed and fabbed an airation system for the props and have since pounded 160hrs onto the drive without a failure
Building a bigger motor this winter. Will have the drive freshened and we'll see what it can take next summer.
PS, My daytona with a 500efi averaged 30 hrs per Bravo before the switch to the bh drive.
Any close up pics of your venting of the props ?
MikeyFIN is offline
Old 07-14-2008 | 04:41 AM
Dan,
Did you take the pics too ?
MikeyFIN is offline
