Number six on a single vee - Pros and cons? >
Old 02-04-2008 | 12:29 PM
  #41
I would go with the Konrad speedmaster version. It would handle the h.p. without any problem and much less weight than a six. Your boat would run much faster. And take less h.p. away from the engine.
John the Drive Man is offline
Old 03-24-2008 | 07:38 PM
  #42
Originally Posted by check300
Cougarman has done a good job explaining my setup. It was a lot of work because we didn't know how high to mount the drive and Mercury didn't have a clue. I am putting big power through the drive and have not had a single issue. It is so nice to not be held "hostage" by the drive.
Are you running the trans in a Stellings Box? What trans are you running and were there many modifications to the box to do this? How is the rooster tail coming out of a single 6?
-Tom
ToMorrow44 is offline
Old 03-24-2008 | 08:36 PM
  #43
cougarman's Avatar
-Tom
Check300 is running a Stelling Extension Box.
I believe he is running a Bam Transmission.
Can't remeber on the mod's the flange may be trimmed a bit
for the tranny clearance, nothing a good sawzaw can't handle.
They also cut the bottom out and then just mad a cover that bolts on for access. All really elementary changes that can be easily made.
Jon
cougarman is offline
Old 03-25-2008 | 05:25 AM
  #44
Unhappy
Originally Posted by masher44
You need room in the bilge for a tranny...
For sure.. NO SPACE here.
That's why I run my boat like grandma drives her car....
BTW: Really like your Activator, looks awesome!!
Mange
Attached Thumbnails Number six on a single vee - Pros and cons?-first-09.jpg   Number six on a single vee - Pros and cons?-first-10.jpg
Mange is offline
Old 03-25-2008 | 02:34 PM
  #45
cougarman's Avatar
Mange
Check300 eliminated your problem by using a Stellings Extension box and having the tranny inside it.
Jon
Old 05-16-2008 | 07:25 PM
  #46
Elite Marine's Avatar
Any update to this thread?
Elite Marine is offline
Old 05-22-2008 | 10:30 AM
  #47
IRONMAN's Avatar
What is the standard drive shaft to prop shaft centerline distance (height) on a #6 drive?
IRONMAN is offline
Old 05-22-2008 | 11:16 AM
  #48
I believe 24"
Boatlesss is offline
Old 05-22-2008 | 11:32 AM
  #49
cougarman's Avatar
Trying to fins some old prints, I may be wrong but 24" sounds way to deep.
seem's like it's on the high side of 16" but I don't dare say with out finding those prints
Old 05-22-2008 | 11:52 AM
  #50
Brad Zastrow's Avatar
I would not weld a skeg on any drive like that. On a single it is critical to have a good skeg to steer. Herring's that are welded on are done to the back of the skeg not the whole skeg. Single outboard go fast boats will break a skeg off at times from the torque steer of the one prop trying to twist the drive. Those O/B lower units are junked without the skeg with no exceptions. Welding it only fatigues the metal in another area and it will break off again and then the outboard boat may crash
Brad Zastrow is offline
