Free play
Old 03-26-2008 | 11:40 AM
Veteran: Army
Sorry for the wrong info but I knew it was something with the gimbal,guess I wasn't thinking enough!! I had the same problem and had it fixed and added external steering at the same time..
snopro13 is offline
Old 03-27-2008 | 07:22 AM
Originally Posted by Fast Willy
Have a bravo 1 & when you move the outdrive side to side with your hands it goes about 2 inches each way. Looking at the steering wheel while doing this it doesn;'t move. So since I just pulled the engine I wanted to get this straightened out. Something has to be worn out, but I have no idea what it could be. Boat has standard cable style steering.
The first, and obvious, place to look is the steering cable itself. Over time they just chit out, check the helm unit as well. The key here is your statement that when moving the drive that much the wheel is not moving with it. There is no way that much movement is not going to be all in the drive assembly. Second place to go would be the upper pin where the gimble ring attaches to the transom assembly, they can wear or loosen over time, Merc has a repair kit for this, have seen the kit installed many times with no adverse effects on a normal boat. The way to check for wear here is to lift on the tail of the drive and watch/feel for movement in the pin. If you are not sure of your abilities to diagnose this take it to a good marine repair facility, if something fails in the steering, even at modest speeds, you can get into trouble. Full hydraulic steering is the ultimate system, if you do not want to spend that kind of money simply replace the entire system,cable and helm, that you have now, it is not that expensive to do, you should then be good for many years to come.
RaggedEdge is offline
Old 06-22-2008 | 12:21 PM
Where can this kit be ordered from and what type of money are we talking about to have someone fix it. Seems to be a job that is a bit out of my do it yourself range
cougar25 is offline
Old 06-23-2008 | 12:16 AM
BY U BOY's Avatar
www.jrmarine.com its about 50 bucks but you will also need a new gimble about 900.00 new.Sometimes you can find them on ebay for about 400. You can also send the gimble ring to jr marine and they will weld it and machine back to new. 250.00
BY U BOY is offline
Old 06-23-2008 | 10:24 PM
I talked to a mechanic today and I am bringing the boat to him this week end. He said I need to put hydraulic steering on it also. I know it will help and I intended to install one. It was on my list of things I wanted to do. I really do not have the money to do it at this point. If I fix the problem at hand it should be ok til the offseason when i have more money to upgrade the steering to hydraulic. He says if I don't I will have same problem and have to repeat the repair. It took 7 years for it to get to this point will two months really hurt? Also he said he does not do the cutting into housing fix he will pull the motor to get to it.
cougar25 is offline
Old 07-06-2008 | 06:07 PM
i have a similar problem on an '06 boat with like 50 hrs on it.... the cables could'nt have stretched and just need adjustment?.... my boat only runs high sixty's should i also be considering hydraulic steering?
007joe is offline
Old 06-28-2010 | 06:43 AM
Default External?
Where could I see an example of external steering? I have an 89 25 ft Rogue, with aa Bravo 1. Gimbal appears to be ok, and am pretty sure my steering arm is shot. I MIGHT be able to get at it from the inside, as I have quite a bit of room to work with, but if not, planned on going with the external repair kit...Thanks for your help...Den
Den P is offline
Old 09-20-2010 | 06:12 PM
Revspan's Avatar
Does anyone have an idea of how much play would be considered acceptable? I have about 5/8 of an inch measured from the prop area(as far away from the gimble as possible). Thanks
Revspan is offline
Old 09-21-2010 | 07:40 AM
txriverrat2001's Avatar
Around here that's good.... I've seen 'em swing 3-4 inches.... and they still drive them.....
txriverrat2001 is offline
CPPerformance
New Products and Member Discounts
5
10-23-2008 06:49 PM
ratman
09-08-2006 01:06 PM
Reindl Powerboats
10-15-2002 02:09 PM
FunHome
06-10-2002 11:12 AM
