Drive Depth
Old 04-01-2008 | 09:59 AM
Default Drive Depth
If Im going from standard alphas to standard bravo 1s how much deeper is that going to put my prop shaft ? can I plug any other lowers (mercruiser or aftermarket ) into my bravo 1 uppers to raise the propshaft depth ?
rumblfish1966 is offline
Old 04-01-2008 | 11:47 AM
You can use Imco shorty lowers. They come in -1, -2, and -3 inch. Lots of $$$ though.
Griff is offline
Old 04-01-2008 | 11:51 AM
Changing from alpha's to bravo's raises the X dimension...prop shaft will be higher...don't know how much...I had the alpha changed to a Bravo on my Pachanga.
pachanga is offline
Old 04-01-2008 | 12:05 PM
Mbam's Avatar
Offshoreonly Advertiser
The actual distance from crank center to propshaft is the exact same, 21 13/16. The (stock) Bravo put's the prop back another 3" or so which is about the same as lowering the drive 3/8"
Mbam is offline
Old 04-01-2008 | 03:10 PM
Hmmmm If it's the same....does placing the prop back 3 inches raise the X dimension?(My boat guy told me it raised it quite a bit) LOL...See how much I know. The alpha always kept a bite...the bravo will loose it's bite from time to time at lower speeds. I don't see where raising the propshaft would help in my situation unless I was trying to mimic a surface drive! Then I would start worrying about my water pickups...course a sea strainer would be an option.
pachanga is offline
Old 04-02-2008 | 06:25 AM
mercruiser doesnt make anything shorter that will plug in ? I realize each hull is different but is there a rough "ideal" dimension for the propshaft to bottom of hull measurement ? Im talking about your average twin I/O ,non notched,non step,V hull
CB-BLR
Nordic
23
10-27-2008 03:15 PM
rssteiny
0
08-03-2007 06:31 AM
Linster
1
05-01-2005 06:22 AM
bryanspeedracer
05-27-2004 01:28 PM
