TRS Question
Old 05-06-2008 | 03:32 PM
BDiggity's Avatar
Default TRS Question
Is the sea pump on a TRS boat in the drive itself or mounted on the engine like on a Bravo? Been doing some reading & i thought it said have to take drive off boat in order to change the impeller. Is this correct?
Trying to figure out the part # i need for the impeller kit & the procedure on how to change.
BDiggity is offline
Old 05-06-2008 | 05:53 PM
On the engine like a bravo
MOBILEMERCMAN is offline
Old 05-06-2008 | 07:31 PM
I concur.......
Pismo10 is offline
Old 05-06-2008 | 08:16 PM
BDiggity's Avatar
Thanks, i dont know what i was reading then.
BDiggity is offline
Old 05-06-2008 | 09:55 PM
jeff32's Avatar
but not same model (housing) as bravo... impeller is the same.
jeff32 is offline
Old 05-07-2008 | 09:12 AM
BDiggity's Avatar
i *think* this may be the 2 piece housing & not the 1 piece like bravos. i wanted to have all the parts purchased so when i go back down in 2 weeks i can start the work. i may just buy the impellers & not worry about the housing unless i get it off & decide it needs replacing.
BDiggity is offline
Old 05-07-2008 | 09:18 AM
The old 2 piece has paper gaskets you will have to replace them with new ones plus the housing does wear out too. The new one piece also works. Just buy the whole one piece kit and get it done with in one attempt.
Old 05-07-2008 | 05:05 PM
jeff32's Avatar
are you saying the one piece bravo style would be Ok (would fit) on my engines?
jeff32 is offline
Old 05-07-2008 | 05:24 PM
yes-that is what I use
Westcoast is offline
Old 09-25-2008 | 07:07 AM
c_deezy's Avatar
How do you use the one-piece housing with offshore mounts? And where can you find the plastic part of the old two-piece housing?
c_deezy is offline
