Bravo lower question? >
Old 08-05-2008 | 10:28 PM
Default Bravo lower question?
I have a Bravo 1 Performance low water pick up.
Port motor prop spins free by hand both ways starboard seems to have tight spots. You can turn it by hand but it hits a few hard spots that almost stop you from turning.
Drained oil today both drives and they were clean. Magnets were clean.
My props spin inward and it only seems tight turn clockwise.
Boat has no signs of any problems.
Any suggestions?
Trueser is offline
Old 08-06-2008 | 08:23 PM
Vinny P's Avatar
I hate the winter!!
If that drive has tight spots, you have bad things happening inside. Exactly what woud be a guess. At the very least, you need to take apart the lower for inspection. The unusual thing is that there is no metal in the oil or the magnet.
Vinny P is offline
Old 08-06-2008 | 09:06 PM
Make sure drive cable adjusted properly might be feeling clutch trying to grab a little,also if thrust washer worn prop could be rubbing case,but doesn't explain only one direction.If gear lube looks good usually everthing inside is ok
MDGperformance is offline
Old 08-06-2008 | 10:56 PM
I was thinking the same thing on the prop. same issue with the prop off.
Need to check the adjustment and see if the prop spins in neutral.
Trueser is offline
Old 08-07-2008 | 01:54 AM
hillbilly24's Avatar
If it is only doing it in one direction it is an issue with the shift mechanism. Might just be an adjustment but it could also be a bad shift cable that has allowed water to intrude into the shift. Either way you have to pull the drive to check it, Bravo shift cables are set up with the drive off, while you have it off have a look at the shift link, thats the piece that the shift cable ends snaps into. If it is corroded you should replace the drive end shift cable and remove the back cap form the drive and clean up or replace any corroded parts. It;s not really that big of a job and only a few fairly inexpensive specialty tools are required. If it is a water intrusion issue it will only get worse so you may as well check it out sooner then later.
hillbilly24 is offline
Old 08-07-2008 | 09:00 AM
Mr Gadgets's Avatar
Charter Member #601
Trueser,
I believe we discussed this on the phone the other day, did you try the things I suggested and any change in the results??
Dick
Mr Gadgets is offline
Old 08-07-2008 | 03:34 PM
I will try those this weekend,
THanks you for your help.
Trueser is offline
BillR
1
06-20-2007 08:21 AM
Smarty
13
06-17-2007 11:08 AM
dckrafft
2
04-16-2006 01:21 PM
glassdave
2
04-15-2006 10:21 PM
dckrafft
3
01-18-2006 09:12 PM
