Drive slowly dropping >
Old 08-25-2008 | 08:04 PM
Default Drive slowly dropping
I have a 87' with Alpha drives, when setting ether in the trailer position or down my port drive slowly drops ( an inch or two a day ) can anyone help me with this? could I be low on oil?
Flamingo 42 is offline
Old 08-26-2008 | 07:08 AM
Registered User
not low on oil . You either have a bad seal in one of the rams or a problem in the pump itself. In the service manuel there is a series of test to locate the problem.
clpbs is offline
Old 08-26-2008 | 08:25 AM
737jetmech's Avatar
The pumps have check valves . Inspect the rams for leaks if none are found ... Pull the pump apart ... clean the valves and reinstall.
Bob
737jetmech is offline
Old 08-26-2008 | 05:47 PM
no leaks on the rams, I will look at the manual again didnt see any type of troubleshooting first time through, no sign of leaks on the pump ether I have the oildyne/eaton pump
Old 08-26-2008 | 05:54 PM
I had the same problem before. It was in the trim pump. I got a good deal and just replaced the entire pump assembly.
Griff is offline
Old 08-26-2008 | 07:11 PM
monstaaa's Avatar
depending on the year trim pumps are either internally bypassed or have a manual release. look for a sloted screw head between the trim lines and check for tightness. other wise the suggestions abvove pretty much sum it up.
monstaaa is offline
drypipetiger
09-04-2008 06:36 PM
Chart
01-07-2008 09:06 AM
kipstone
09-16-2006 01:46 PM
SANLEONKID
Scarab
8
08-26-2006 11:43 PM
vegas daytona
8
05-17-2005 05:57 PM
