HELP, drive res. fitting in transom >
Old 09-03-2008 | 03:26 PM
Default HELP, drive res. fitting in transom
The fitting that goes through the transom to the drive broke off and dumped all the drive lube in the bilge. Does it unscrew out of there? What is the fastest way to fix this. Headed to Poker Run tomorrow!
Plane Silly is offline
Old 09-03-2008 | 03:58 PM
If it is a plastic fitting, all you should have to do is push the locking clip in and pull it off.
debcod2 is offline
Old 09-03-2008 | 04:10 PM
Can the piece that comes through the transom be replaced with a brass fitting?
Old 09-03-2008 | 06:05 PM
Well I was able to push and clamp a hose onto the straight fitting coming through the transom for now. Seems to be working in the driveway ok.
glassdave
05-22-2008 11:37 PM
Bryan Rose
2
05-18-2008 03:16 PM
Cattitude
Drives and Lower Units
2
05-10-2007 11:20 AM
29KILROY
2
08-18-2005 06:21 AM
jcap
4
07-05-2003 12:03 PM
