Drive oil in Gimbal Boot >
Old 12-07-2008 | 01:01 PM
blown formula's Avatar
Cool Drive oil in Gimbal Boot
I removed my port B1 yesterday (prior to removing the engines again!) from my Sonic & had drive oil (about a pint or so) run out on the floor from the gimbal boot. It was pooled up in the gimbal boot clear to the floor of the gimbal helmet.I have never seen this before. I can see no obvious leak source from anywhere but the entire input shaft & u-joints were soaked in drive oil. I can only suspect a leaking input shaft seal leaking into the gimbal...... any other ideas???
blown formula is offline
Old 12-07-2008 | 01:38 PM
NO,,,that should be it .
DareDevil is offline
Old 12-07-2008 | 03:48 PM
Mr Gadgets's Avatar
Charter Member #601
Usually the input shaft seal will cause this, but if the oring in front of the pinion retainer nut is bad.. that could cause it also. I would do a presure test, 10-15lbs and see if it holds over nite.. if not then soap it up and look for the leak..
Hope that helps.
Dick
Mr Gadgets is offline
Old 12-07-2008 | 07:08 PM
Vinny P's Avatar
I hate the winter!!
As Dick said, its either the shaft seal or the O ring that goes on the nut. If you are taking it apart, just replace both of them. Be aware, there are 2 lip seals for different year drives, old style and new style. If you have the older style XR, I would suggest updating the nut and seal to the newer style. The old style nut, didnt support the seal as well, and were prone to having the seal push out through the nut. To replace the lip seal, you will have to take the driveshaft apart and reset the bearing preload. Dont forget to time the gears when re-installing the shaft.
Vinny P is offline
Old 12-07-2008 | 09:54 PM
That's what I thought...... I will just replace both seals. It seems the best & only thing to do!!
Thanks for the opinions.
Old 12-12-2008 | 11:04 AM
Tarheel's Avatar
Registered User
Make sure to check for wear on the input shaft too. Mine had some pretty good wear where the shaft goes through the seal due to the previous owner running engines with the drives trimmed out too much.
Had to replace the yoke assembly in my case...and its sold as a single unit from Merc as I recall.
Tarheel is offline
Old 12-12-2008 | 01:51 PM
Yeh, gotta check everything while in there.... good thing I have spare yokes, shafts, knuckles, etc. in the shop. You never know when you are gonna need it!!
George
Btharbold
Drives and Lower Units
8
07-21-2009 03:31 PM
byrideroffshore
Wanted
4
12-01-2008 09:25 PM
mcraymond3
11
10-20-2003 08:22 PM
p4-33
2
07-08-2003 03:41 PM
blackhawk
2
05-11-2002 01:13 PM
