Which Bravo drive? >
Which Bravo drive?
Which Bravo drive?
Old 02-09-2009 | 11:00 PM
outlawinil's Avatar
Default Which Bravo drive?
What bravo drive was hooked up to a 2003 496 Mag HO? Boat is 350 miles away and I can't tell from pictures. Is Bravo 1 standard?
outlawinil is offline
Old 02-09-2009 | 11:53 PM
It could be Bravo1, X, or, XR. Depends on what the owner wanted.
Darrell.
DMOORE is offline
Old 02-09-2009 | 11:58 PM
outlawinil's Avatar
Pardon my ignorance...I was thinking they put a more beefier outdrive than the regular bravo 1 outdrive behind the mag HO
Old 02-10-2009 | 12:55 PM
Its most likely a Bravo 1 X.
Griff is offline
Old 02-10-2009 | 01:51 PM
Ditto
JaayTeee is offline
Old 02-11-2009 | 09:20 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Standard bravo one on the earlier ones was standard, however they did start packaging them with the B1x as the unit that went with 496 Mag ho I think around 04, also yes you could usually upgrade toa heavier version yet if you wanted to.. Jamie..
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 02-11-2009 | 11:36 AM
outlawinil's Avatar
Will an XR outdrive bolt on to a standard bravo setup. Is the gimbal bearing the same or is the shaft going through the gimbal bearing bigger?
Old 02-11-2009 | 12:27 PM
You need to change the gimbal bearing.
Griff is offline
Old 02-11-2009 | 02:00 PM
Mercury has used the same bearing since the begining of time the only difference in any of them is the length of an ITS U joint assembly. They do have a couple different Ujoint configurations but they all fit each other.
Pink Propellers is offline
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
1BIGJIM
Wanted
10
05-16-2008 10:12 AM
rhory
1
05-19-2004 06:52 AM
Chris288
1
04-13-2004 11:19 AM
panteraracin
3
02-07-2002 10:36 PM
