Bravo Side Fitting? >
Bravo Side Fitting?
Bravo Side Fitting?
Old 03-16-2009 | 11:31 AM
Default Bravo Side Fitting?
On the side of the upper case there is a fitting that is screwed into the case that points backward? The fitting is threaded into the case and is open on the other end? Does anyone know what this could be for? Note that the drive pickups are not used since I have separate water pickups on the hull but the drives still have the water pickup holes in the lower case.
stormbauer is offline
Old 03-16-2009 | 12:46 PM
Probably for the water speedo tube.
Griff is offline
Old 03-16-2009 | 01:00 PM
Does it look like someome drilled hole to direct water from stock pick up to use as drive shower
Clustergear is offline
Old 03-16-2009 | 01:08 PM
Boater8987's Avatar
Airking
Maybe- Water still needs to circulate thru the drive for cooling of the oil and that fitting would be the water outlet?
Boater8987 is offline
Old 03-16-2009 | 07:37 PM
Mr Gadgets's Avatar
Charter Member #601
Water does need to flow thru the drive to cool it!!! On a transom pickup boat, that is one of the techniques to keep water flowing. You can also put a fitting on it so that it points at the side of the case above the water jacket, or put a pipe over the top or around the back with holes in it to spray on the upper case.. the more the merrier!!
Hope that helps.
Dick
Mr Gadgets is offline
Old 03-16-2009 | 08:36 PM
I di that when i raced Bravo's,,,had the water from the Drive pick up spray against the gimbal to cool the drive inside and the back side !!!!
Oh,,yes my boat also had transom pickups !!!
So instead of the water going thru the gimbal it sprayed onto the gimbal .
If u could post a picture ,,,it would probably be easyer to tell !!!
DareDevil is offline
Old 03-16-2009 | 09:15 PM
I will get a picture and post. Make sense that it is water outlet. Also already has separate drive shower.
Old 03-16-2009 | 09:20 PM
The driveshower only cools the upper and what we did was cooling the complete drive ( kind of )
never had a problem with twin 650 + on a heavy 28 foot boat turning @ 7000 RPM going about 100+ . THAT IS FUN !!
Old 03-20-2009 | 07:51 PM
See pictures
[ATTACH]Bravo Side Fitting?-p3200037.jpg[/ATTACH]
Old 03-21-2009 | 02:55 AM
That fitting is tapped right into the water jacket on the drive. It is either for an old drive shower feed or is the dump for the water that goes into the drive. I had my drive shower on my Pantera fed from that exact spot. I had a hull p/u for the engine. I also had a dump on the side of the boat where water coming in the drive would dump overboard.
Griff is offline
