TRS Bearings
Old 03-19-2009 | 10:18 PM
Default TRS Bearings
Are the bearings in a TRS only available from merc, or are they a standard type bearing available from a bearing supplier?
MILD THUNDER is offline
Old 03-19-2009 | 10:42 PM
I would say the second quess !!
DareDevil is offline
Old 03-20-2009 | 12:04 AM
I rebuilt my TRS about 15 years ago and was able to get all the bearings except one at a local bearing supply house.It was the pinion bearing in the bottom end.They checked into it for me and told me the manufacturer said they could only sell it to Mercury.It may be available now though,I don't know.
picklenjim is offline
Old 03-20-2009 | 08:25 AM
If you can get the bearing number you can buy at your local bearing store for about 1/3 the price of OEM.
Harvey is offline
Old 03-20-2009 | 07:11 PM
J-Bonz's Avatar
Yup, picklenjim & Harvey are correct.............. Grab the numbers and replace with the same brand. I beleive there Timkens.
Jr.
J-Bonz is offline
Old 03-26-2009 | 07:53 PM
Ya,their all taper Timkins except 2 which are the pinion bearing on the lower drive shaft and the prop shaft bearing in the carrier.Their straight roller Torringtons.
Old 03-26-2009 | 08:01 PM
spazboz's Avatar
Yup, just ordered them yesterday from my buddies electric motor repair shop!
spazboz is offline
excursion
Drives and Lower Units
5
09-05-2007 05:30 PM
Rookie
2
02-01-2007 12:57 PM
SSComp
2
05-12-2003 10:48 AM
boot
07-16-2002 12:15 AM
