Replacement Skegs
Did I read here that somebody sells skegs they cut off of drives that come in that are beyond help?
That way we can cut and weld in a piece on a broken skeg instead of welding up and grinding back down a piece of plate aluminum.
I posted that info not long ago. I bought 2 new cutoff skegs thru BAM a few yrs ago. They were approx $20 each. A whole lot easier than shaping a flat peice of AL, plus they'll be the same alloy of AL.
Aluminum maschine shop ,,can cut u a piece of aluminum and weld it on ,,,then grind it to shape.
Thats what i did with my SSM and is on there since a year with no problems and u can't tell !!!!
Come on people ,,be a little more flexible.
As soon as u start welding ,,its heat ,,does not matter if the weld is 1 inch or 4 inches ,,,u just got to do it in steps ,,,,??!!
How hard is it to cut a flat piece of Aluminum and weld it on after u cut the old part straight,,,and then u just take a grinder and shape it in what ever shape it should be .
Cost me 65 USD in a shop !!!!
How much do u think a finished skeg is ???
And itas nothing diffrent exept it has the shape already befor u weld .
I don't get it ,,,i quess ?????!!!!!
