Replacement Skegs
Old 05-04-2009 | 09:45 PM
2112's Avatar
Originally Posted by daredevil
How do u figure that ????
As soon as u start welding ,,its heat ,,does not matter if the weld is 1 inch or 4 inches ,,,u just got to do it in steps ,,,,??!!
How hard is it to cut a flat piece of Aluminum and weld it on after u cut the old part straight,,,and then u just take a grinder and shape it in what ever shape it should be .
Cost me 65 USD in a shop !!!!
How much do u think a finished skeg is ???
And itas nothing diffrent exept it has the shape already befor u weld .
I don't get it ,,,i quess ?????!!!!!
I am not arguing your point. It is less welding, grinding and re-welding this way. My welder requested it.
Just hoping to find a skeg.
2112 is offline
Old 05-05-2009 | 12:42 AM
Check mertenmarine.com Then look under" Replacement Skegs". They have several replacement skeg blanks they sell starting at $25.There are several places on the internet that have them.Just look up replacement skegs!! Also if you have any local prop shops look there.They usually do skeg repair and have the blanks there.You may even want to have them do it beings they are experienced at it.
picklenjim is offline
