Please HELP
Old 06-21-2009 | 12:50 PM
Default Please HELP
Hey guy's im new here and hoping i could get get some help.I have a 2000 donzi 22ft zx it has a 350 merc mag and alpha one outdrive it appers to be stock.Yesterday i was running along at about 35-40 mph and about 3500-4000rpm i had the boat slighty trimed.All of the sudden i heard a grinding sound kinda like when you drop it into gear,but louder and faster then the boat stalled before i could shut it down.I checked everything and it looked good so i attempted to restart it .The motor made about 4 revolutions and then froze.When i tried to start it again it would'nt even make a full revolution.It tries to turn over but its like the motors locked up.Has enyone had this problem before.I dont know much about boats but i know a good bit about car motors.Could the out drive be broke and keeping the motor from turning over?? Or would you say the motor locked up. P.S i was in deep water and didnt hit anything.Any info would be gratly appericated
slick26 is offline
Old 06-21-2009 | 12:54 PM
Take the drive off,,,,6 nuts and 2 on the rams .. as easy as that and u will find out !!!
Sorry to hear this togh.
DareDevil is offline
Old 06-21-2009 | 01:31 PM
Thanks i did'nt know that they came off that easy i'll try it.
slick26 is offline
Old 06-21-2009 | 02:16 PM
Ok i went out there took it off and she fired right up.So now that i know its the out drive what should i do.Should i just get it rebuilt or should i step it up.Ive heard of these extreme drives and stuff like that.I plan on building the motor up to about 475hp over winter.Or i might just add a pro charger or something or the sorts.But since its broke now would be the time to up grade.How much power will the stock ones hold,and how much would it cost to get somthing better?
slick26 is offline
Old 06-21-2009 | 02:28 PM
Alpha 1's can handle 400hp, if you're very nice to it.
jtmarten is offline
Old 06-21-2009 | 02:32 PM
How much more would it cost to get somthing better
slick26 is offline
Old 06-21-2009 | 02:39 PM
to get "better" you would need to go to a Bravo,
used you may get lucky and find an entire used setup for
around $4000 and you would need to also add a seapump
to your engine as Bravos dont have one like the Alpha.
New you would probably be looking at $8000 by the time all is said and done.
Luckily I still havent broken my 26 year old Alpha 1 even with a 502.
HTRDLNCN is offline
You could buy a nice used Bravo transom assembly/drive for a few thousand. Then just drill two additional holes for the Bravo setup and your good to go. Sell the Alpha stuff to offset the cost.
jdub is offline
Old 06-21-2009 | 02:40 PM
Damn....that's pretty funny. Beat me by a couple seconds
jdub is offline
Old 06-21-2009 | 02:43 PM
Thanks guys is there any way to just strengthen the alpha?or what ya got is what ya get?
slick26 is offline
