Which drive?
Old 09-06-2009 | 07:36 PM
Default Which drive?
Iam going to build a 600+ cid N/A motor for it over the winter and probably shooting for 650-700hp. I have a TRS set-up on it now and know there is transome work,etc to convert from the trs but what is the best drive to get to handle the new power for next year? I dont think a bravo will handle the power so what's next a XR bravo?
Erik
crapr6 is offline
Old 09-06-2009 | 08:26 PM
http://www.konradmarine.com/index.cfm?optionid=8284
Konrad 540 PRS would be easiest . It's made as a high performance replacement for the TRS. Pretty much bolts on to the existing transom assembly. Don't know what your budget is but their around 10K.
picklenjim is offline
Old 09-06-2009 | 11:24 PM
CB-BLR's Avatar
Chris
I would go with an IMCO SCX upper, and and IMCO SC lower. IMCO reports that they have yet to see a broken SCX. The SC lower is faster than the SCX lower. This is a direct, bolt on replacement and is rated at 1000hp.
Chris
CB-BLR is offline
Old 09-07-2009 | 06:34 AM
T-Mone's Avatar
T-Mone
if interesterd i have a bravo xr plus the dual rams for steering
Ron.
T-Mone is offline
Old 09-07-2009 | 08:02 AM
Ron.
Just PM'ed you..will be in long island today picking up some motor parts but will be home later today.
Erik
crapr6 is offline
Old 09-07-2009 | 10:18 AM
Rookie's Avatar
Chris
For a TRS?????
Rookie is offline
Old 09-07-2009 | 01:39 PM
Originally Posted by Rookie
For a TRS?????
Their a replacement for a Bravo with a helmet change.SCX uppers are $9300 and SC lowers are $4100. That's $13400 and you would have to change to a bravo transom assembly which would require fiberglass work on the transom and you would have to move the engine back a foot to eliminate the transmission.You would have to buy a coupler($500) and then you also have your steering to change.
Konrad is a 10K one day job. Of course you could always just fix your TRS.
Old 09-07-2009 | 02:23 PM
CB-BLR's Avatar
Chris
I didnt catch that it was a TRS. I would go with the Konrad drive also. Easy swap.
Chris
CB-BLR is offline
Old 09-07-2009 | 06:39 PM
So is there anyway I can find a set of gears for the lower unit for the TRS? If its possible to just repair it for now since it is just the lower gear set that are destroyed... that would save me some $$$$$ which would help me out big time right now.
Thanks guys
Erik
crapr6 is offline
Old 09-07-2009 | 08:02 PM
Yes they are still available from Mercury. Pinion gear is $290 and the drive gear is $288 plus shipping from this place. Mercury price is only a few dollars more each but there would be no shipping. You would have to have them installed at a reputable shop (shimming required with special tools)that is equipped to do TRS drives.Labor would probably be about $250.Then they would probably want to replace some bearings and seals which would probably be about $200 more. You would get out with about a $1000 bill.http://www.perfprotech.com/store/ass....aspx#assembly
