Lazy trim ram cylinders-Help
There is valving in the pump. Also the orings in the cylinder could be leaking. I have never had the cylinders apart, but I did have the pump apart. You would need a manual to follow the flow. If something was is stuck in a check valve or a bypass valve that could cause the problem??
Dick
Dick
just oredered a new set of SEI cylinders. You can buy the whole assembly, ready to go for about the same price as the rebuild kit from Merc. Don't know if it will work out, but it is worth a try...they have a warranty too.
Thank you for the order Kai.
Bill
Bill
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
