drive coupler failure >
Old 03-17-2010 | 06:20 PM
ballon78's Avatar
Any problem using grade 8 bolts to fasten the coupler to the flywheel on a 502? the stock bolts have washers bilt in, can i just use a flat washer and bolt and locktight? or should i use lock washers and grade 8 bolts, just bolke one torqueing it and tring to finish tonight.... thanks
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
