What is your oudrive depth? >
Old 09-24-2009 | 06:14 AM
-93 (non step) 27 Fever, 4,5" below.
HP500, 70 mph / 5200rpm with a 14,5X24 4 blade Mach prop.
bl
badluck is offline
Old 09-24-2009 | 07:23 AM
Originally Posted by jeffswav
I assume you were at 7" before the shortie. What gains did you see with the shortie drive?
Yes I was around 7 before shortie, total gains 3-3 1/2 shortie and labbed prop, better handleing boat at WOT also. Takes a little longer to plan, runns flatter but better handleing overall
osur866 is offline
Old 09-24-2009 | 03:42 PM
2.5" prop shaft height. ITS box. Bravo 1 32" Labbed.
Boat ran a personal best of 102mph.
Philm is offline
Old 09-24-2009 | 06:50 PM
Originally Posted by CB-BLR
I run the propshaft 3.5" below the keel spinning a 30 pitch P5x doing 92.5 mph with 730 Whipplecharged horsepower.
Always lookin for more,
Chris
What type of drive? XR,ZX ? I know you and John have done tons of testing and info swapping. I have no one to work with,I'm the only nut with a 100mph 25 sunsation.
risingsun is offline
Old 09-24-2009 | 09:34 PM
Challenger was 5.5" below the pad stock. With an 2.5" Alpha SS shorty it's now right around 3" below the pad. Had to go to a QIV over a 3 blade cleaver to correct alot of slip. Runs 80GPS with a SBC..
Ryan00TJ is offline
Old 09-25-2009 | 01:25 AM
My 28 Pantera with notched transom was 4.75" below the bottom with a 3" spacer. With a 2" spacer at 3.75, it was to high and couldn't leverage the bow enough.
I haven't ever really checked the height on my 32 AT.
Griff is offline
Old 09-26-2009 | 11:01 AM
CB-BLR's Avatar
Chris
IMCO SC drive and lower.
I would really like to get your friends phone number to find out how deep he is running on the yellow Heat.
Chris
CB-BLR is offline
Old 09-26-2009 | 07:18 PM
Chris
both of us are going to a shoot out in a week, I'll check,I do know it's a stock length drive.
Old 09-26-2009 | 07:50 PM
CB-BLR's Avatar
Chris
Nordic set the drives at all different heights.
Check it and let me know please.
Thanks,
Chris
CB-BLR is offline
Old 09-26-2009 | 08:05 PM
2001 Stingray 230LX, my propshaft is 7.5" below the notched transom and running about 69 with a 430hp (prop) SBC. My speeds range between 68.7 and 70.5 depending which prop I have on it. I have tried a Laser II, a Tempest, a Rev4, and a Mirage +. The mirage makes the boat feel very loose and I have to over trim it to get max speed, but it has the least tendancy to chine walk. I have a -2 XR lower that I am going to try next weekend. I was a little disappointed on how fast the boat went when I got the motor in it, but I still dialing in the driveline. I was expecting mid 70's and I hope the shorty gets me there.
ACrooks69 is offline
