What Gear lube are you running in your TRS
TYPE F equivalent. I forget what brand I have in their. I think it is either Valvoline or Mobil. Probably synthetic something.
I would recommend this........
http://www.amsoil.com/storefront/art.aspx
I ran Mobil 423 Hyd fluid in my BW tranny for years. No foaming. The fluid was so clean every year when I changed it that it looked like new fluid. I learned this back in the 80's from the guy that was doing the BW that were used behind the high HP HAWK motors. Another good mod for the BW trannys is to remove the thrust washers and machine case and replace the thrust washers with flat roller bearings the tranny will last for years.
