Open Question to Mr Gadgets and Anyone else with input ... >
Old 12-17-2009 | 04:27 PM
blue thunder's Avatar
Originally Posted by Mr Gadgets
Mike,
you wont have any trouble with the oil holes on the new ones. I think that was very early 90's that you would have to worry about it.. If you have any questions I can take pics to show u.. If need be. When you do mix and match the old ones you need to drill a hole to compensate for it. But mid 90's to present will match up, no problem.
Dick
What hole needs to be drilled Mr G? I've been running a mosh bosh of uppers/lowers with varying oil hole configs. All I have been doing is plugging the oil hole in either the upper or lower, which ever didn't have a mate. Is there an additional step I should be taking?
blue thunder is offline
Old 12-17-2009 | 04:39 PM
offthefront's Avatar
I was told the the front oil hole was an attempt by Mercruiser to solve some Drive Failures on higher HP setups and it didn't really help.....So plugging the upper on a newer drive and using the "pre 90" lower is ok .... As MG stated ...
offthefront is offline
Old 12-17-2009 | 04:45 PM
We will see you next week right offthefront? Let me know the location where we meet up.
Dave
Old 12-17-2009 | 05:11 PM
Dave
10-4 ...... I10 and 301 prob .... we'll set it up ....m
Old 12-17-2009 | 06:47 PM
Mr Gadgets's Avatar
Charter Member #601
BT, if you look at an old upper case that doesnt have the oil transfer passage, you can see that there is a hole drilled in the front part of the cavity where the vertical shaft goes into the upper. I have drilled that hole, because that was the way it was done before the hole in the lower was designed.
The theory is that the lower gears act as an oil pump and push oil up to the pinion bearings and it flows over the pinion gear teeth. If you run a bravo with the back cap off, you can see it happening.
Without a hole in the lower, that cavity that supplies oil to the pinion bearings is closed off.. But I am not sure how the added hole affects this process. Just know they had it on the uppers for years before they changed it.
Dick
Mr Gadgets is offline
Old 12-18-2009 | 12:10 PM
I think I get it Dick. If you run a newer upper having the tranfer hole, with a lower with no hole, you have to plug the upper transfer hole automatically. So to get the oil rotating (convecting) into the upper part of the upper you need to cross drill into the oil galley. I'll check that out, thanks for the info.
Dave
Old 12-18-2009 | 01:40 PM
Mr Gadgets's Avatar
Charter Member #601
Yeah, that's it, the hole is on the front side of that cavity that the vertical shaft goes up into the upper ( not sure how to describe that tunnel ) and it is drilled on an angle, if I remember correctly.. a 3/8" hole, but I would have to verify that.. Been a while..
