Bravo idle speed
Old 12-19-2009 | 09:12 PM
Default Bravo idle speed
Can anyone tell me the maximum safe idle rpm for a bravo1. Will they operate properly @ 8-900 rpm? Thanks R. M.
Andrew 19 is offline
Old 12-19-2009 | 09:46 PM
No that is to high, 645 rpm would be the max i would go to be honest Anything over 700 would be pushing the limit.
Boat Tech is offline
Old 12-20-2009 | 03:00 PM
800-900rpms in neutral is fine. Anything above 1000rpms is too high and you'll start having problems with the cone clutch. My last 2 boats before the AT idled around 900rpms in neutral and dropped to about 750rpms in gear. Never had any problems with either drive.
Griff is offline
Old 12-20-2009 | 05:20 PM
THANKS ya'll. R.M.
Old 12-20-2009 | 05:32 PM
obnoxus's Avatar
Charter Member #1171
Correct,,,, never shift a Bravo above 1000 rpms's.
Its a balance though,,,, depending on power,,, you cant idle to low either or you will chance reversion
you should be fine where you are
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 12-20-2009 | 06:05 PM
Mr Gadgets's Avatar
Charter Member #601
I concure.. 800-900 is ok.
Mr Gadgets is offline
Old 01-01-2010 | 07:08 PM
Thanks to all of ya!! Now i'ts on to next thread. Hope we have a good new year. R.
