does anyone know what this is? LOOK! >
Old 01-07-2010 | 12:47 AM
Originally Posted by buck30
have you ever seen an early trs with the same type of long input/yoke shaft? i think i have seen one.
No. All TRS's used transmissions with taik stocks that mounted in the transom assembly there fore there was no need for a long shaft. The input/yoke shaft on a TRS using a Borg Warner has external splines on it. The input/yoke shaft used on a TRS with a Merc Trans ll has internal splines.
picklenjim is offline
Old 01-07-2010 | 12:02 PM
Default 215
215 drive..."nothing" inside compatible with tr/trs. Bluntly; rare and worthless.
rufusgrouse is offline
Old 01-07-2010 | 05:52 PM
They did use the same gear oil.
tms1155 is offline
Old 01-07-2010 | 06:37 PM
marinetrans's Avatar
Yep--makes good winter conversation though.Heres a tidbit---if you shifted the motor w/ the drive off,the clutch plate would fall out of place, have to pull motor and realign clutch disc.
marinetrans is offline
Old 01-07-2010 | 08:52 PM
Mbam's Avatar
Offshoreonly Advertiser
Ran into that drive when I was first getting into the biz - was my worst nightmare. It shifted with a speedo type cable drive by the clutch actuator (if I remember correctly)
Mbam is offline
Old 01-07-2010 | 10:39 PM
thats the one! Anybody that ever touched one remembers it. Worst design in boating history!!!!!!!!!!!!!!
tms1155 is offline
Old 01-08-2010 | 12:00 AM
well its for sale dirt cheap!
buck30 is offline
Old 01-08-2010 | 12:01 AM
thanks again for all the help guys
buck30 is offline
Old 01-15-2010 | 01:47 AM
some of the trs drives did have a tail shaft like a bravo or alpha they were used on staggerd setups with a carrier bearing and driveshaft had a old scarab that was set up that way
sikinboat is offline
Old 01-15-2010 | 02:19 AM
I hear scrap prices are up!
If not, it would make for one helluva anchor...
wjb21ndtown is offline
