Extreme gimbal bearing removal... need help >
Old 03-21-2010 | 02:46 AM
Default Right on!
Originally Posted by mike38scarab
The easiest way to get the gimbal bearing out is to drill into the outside of the race. Drill one hole through the outside of the race and another 180 degrees opposite of the first hole, this will collapse the race and make it easy to pull, the race is soft aluminum. Center punch the race so the drill doesn't cut into the transom mount.
Gimbal bearings that were froze into place easily come out with this method. Forget the slide hammers and trying to use threaded rod. You're not going to re-use the bearing.
Having the bearing install tool is a great investment, it saves time and will seat the bearing fully and properly.
Been there done that.
The bearing has no rust or other signs of being stuck, but it sure is. I was thinking about trying to drill a couple of holes around the edge... Thanks for reafirming my thoughts. I will give it a try.
offshorefisher is offline
