How to remove bravo gimble without removing transom assy? >
Old 04-02-2010 | 08:10 PM
Ona-Mission's Avatar
Default How to remove bravo gimble without removing transom assy?
Can anyone explain to me or point me in the right direction on how to to remove a bravo gimble without removing the transom assy?
Pat
Ona-Mission is offline
Old 04-02-2010 | 08:57 PM
seafordguy's Avatar
Pat
Are the notches in the race facing in or out. If you can see the notches in the housing/race then your life will be incredibly easy, and you can just turn it 90 degrees and then pull it out with your fingers.
If not you can rent a puller and reach through with the jaws, and pull the bearing by pulling against the bellhousing.
seafordguy is offline
Old 04-02-2010 | 09:13 PM
do you mean the gimble housing,or are you talking about the bearing.
mike tkach is offline
Old 04-02-2010 | 09:55 PM
i want to remove the gimble ring without removing the motor and transom assy.
Maybe in not understanding how its all assembled.
Old 04-02-2010 | 10:47 PM
Pat
Take a look at this link to see if it could help you out with your project.
http://www.jrmarine.com/instructions.htm
Boat Tech is offline
Old 04-02-2010 | 11:39 PM
Exactly!
Old 04-03-2010 | 04:51 PM
seafordguy's Avatar
Oh - sorry, misunderstood, thought you meant the bearing housing.
You HAVE to get the bolt on the upper swivel pin, and you could use that kit that he sells at JRMARINE.com.
If you have to get it off, I would just pull the engines. My seals went bad last year and I decided that pulling the engines (despite it being my first time) would probably make the job just as easy....
Old 04-04-2010 | 08:14 AM
thats a great link . i always worder why they just didnt make a plate there when they made the drives .????
bajabob is offline
Old 04-07-2010 | 06:54 AM
Nicolasticity's Avatar
Didnt want to cut up the casing so was thinking of removing the transom assembly with engine in - can that be done? Seems to be a few through transom bolts and I can check the seals and transom too?
Nicolasticity is offline
Old 04-07-2010 | 08:45 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
The time spent trying to reach the bolts and chit behind the motor, you'd be hrs ahead to pull the motor. You can have a motor out in an hr in a single. Providing you do have a hoist. Gotta support thr back anyways to try to leave it in. But I would have to think it's possible, if you don't have thru the prop exhaust. The Y-pipe has bolts that I don't think you will get to with the motor in, and it has to come off to remove the transom assembly.
US1 Fountain is offline
