Gimbal Ring
Old 05-15-2010 | 04:51 PM
Default Gimbal Ring
Hi Guy's I am a new member and I have been reading through Forums looking for a clean thread for my issue, anyway I want to pull the gimbal rinng out and have it rebuilt along with the pin I already pulled the engine and pulled the outdrive because I wanted to clean underneath and clean up the motor. what do I do next?
Thanks for any help.
Sorry for beating up an old issue
Joe
hammertime is offline
Old 05-15-2010 | 05:40 PM
Reply:
Call JR Marine they did one for my boat and it saved me a bundle. In the alternative you could buy a used one but JR does a great job on it damn near new.
You can get everything from them www.jrmarine.com
Take Care
KAP
kap328 is offline
Old 05-15-2010 | 08:43 PM
Yeah thanks for the reply I will probably go that route I am kind of stuck with my next how to fisical next move on the nuts and bolts part of it ,the book is a little sketchy I just need to research and read more I guess.
Old 05-16-2010 | 12:09 AM
spazboz's Avatar
Hey Joe. I live in Holland prob. not too far from you. If you run into too much trouble, let me know and maybe we can take a look at it sometime.
spazboz is offline
Old 05-16-2010 | 08:51 AM
That is very kind of you, I may take you up on that I will be messing with it to day next hurdle is getting the ring off. small wold 6168362439 if you want to call me
Thanks Joe
Old 05-17-2010 | 07:41 PM
Well have everything apart now that I would see more wear and tear then do I had 2-3" of play back and forth the main thing is the tiller arm the pin mics out 3 thousands of in inch of wear at the edges not bad,bottom bushing bad easy fix there, cant figure out why so much play??
