help on1983  trs 330 >
help on1983 trs 330
help on1983 trs 330
Old 05-30-2010 | 01:21 PM
Default help on1983 trs 330
i need schamactics for the trs drives its unbolted and i pryed it and wont come loose
michalski19 is offline
Old 05-30-2010 | 01:39 PM
Assuming that you have removed the trim cyls. and the 6 nuts which hold the drive on lift the drive by hand as if it were trimming up and slide a 1 x 1 piece of wood or something similar between the gimble ring and front of the drive. Let the drive down against the wood. Now lift the drive a few inchs again and let it fall against the wood. It should pop right off.
Here is a place you can down load the manual you need. You need #5 TR/TRS Service Manual
http://forums.iboats.com/showthread.php?p=1693398#post 1693398
picklenjim is offline
Old 05-30-2010 | 06:43 PM
thank u buddy u the man
