Imco Extension Box leaking water >
Old 06-01-2010 | 08:49 PM
Default Imco Extension Box leaking water
I'm guessing it's leaking through the bolts that hold the steering arm on as there really isn't a great way I could see to seal these. I used 3M 4200 to seal the arm to the box, but couldn't see a way to seal the bolts. Anyone got a good way to seal these? I got 2 holes that are oval in the arm and the 3 holes in the box are just straight through. Thinking I need to seal the box from the inside putting silicone on the washers or use 4200 here as well. Only way I see me needing to take the arms off if one gets damaged.
Ideas or experience would be appreciated. Thanks in advance.
Irishtornado is offline
Old 06-08-2010 | 12:26 AM
articfriends's Avatar
When I put a stellings box on my 272 I sealed the steering arm bolts with great stuff rtv,never leaked,shouldn't really be under water though,sure its not leaking somewhwere else? Smitty
articfriends is offline
Old 06-08-2010 | 12:44 AM
I'm positive it's not on the transom or transom assembly. I resealed the wingplate and inspection covers as well as bolts. I'm going to submerge it again to see if I got it. If I didn't my next logical place is blockoff plate and transom assembly seal.
